Help !!! Vivodi Ip
a.sto inside ip panta tha mpenei i ip pou exeis dosei sto tcp ip tis kartas diktiou sou.an to exeis automatic tote apo command prompt grafeis ipconfig kai tin blepeis ekei.b.esi ixes kanei lathos pou ixes dosei tin wan ip pou ixes parei.b)mporeis na bgaleis kai to firewall episis apo telnet 10.0.0.138 kai meta ip config firewalling=off
golden stin vivodi den xeroun ti lene.den xeroun kan ti einai to port forwad kai giati to kanoun,kai akoma kai port forward na min ekanes mporeis na pexeis san passive user.episis iparxei kai to site http://www.portforward.com kai exei gia pola modem,routers pos na kaneis port forward.dr lo genikos to speedtouch exei pola pragmata ta opoia rithmizontai mono apo telnet.kako auto.kapote ixe bgei kai ena programmataki kati san auto to manager pou ipe i vivo pou ekane kapoia pragmata pio eukola alla den thimame oute onoma oute site.pantos to speedtouch san router einai kalos.
Poulino tnx re filaraki.
Apo ri8miseis modem kai ta sxetika den skampazw mia :-|
Eutuxws iparxei kai to insomnia :wink:
By the way oi ipalliloi tis vivodi einai psilo @@res i taxitites tis omws einai poli kales.
Iparxoun stigmes pou pianw 42-45 kb/s sta8era.
Tnx Again Guys :grin: :wink:
pragmati epidi exei tixei na exo mpleksei kai ego kapote me tous ipalilous ekei apla asta na pane.ti travixa mexri na paro ta sosta pragmata.alla oi taxitites tote itan normal oute megales oute mikres apla itan ftina logo dslam vivodi.tora pia exo figei apo vivodi.oti xriasteis kai mporoume na se boithisoume edo imaste.apo to service tis vivodi poli kalitera.
Οπότε τελικά δεν φταιει η Vivodi τζάμπα τα βρισίδια. Εγώ π.χ έχω σεταρει web και ftp server χωρίς κανένα πρόβλημα. Σιγά μην παω στην forthnet να χρυσοπληρώνω την static ip.
den ine i forthnet pou tin xrisoplironeis alla oi pantes ektos apo tin vivo pou exei provlima.alla mipos estises web kai ftp se alles thires pera 80 kai 21 giati kai alloi exoun dokimasei kai tis exoun brei klistes.ektos an se xexasan esena.
Όντως πριν 4 μήνες είχα και εγώ το ίδιο πρόβλημα αλλά από κάποια στιγμή και μετα οι πόρτες ανοίξανε. Η ip που περνώ είναι 83.171.215.χχχ. Δεν ξέρω μπορεί όνος σε αυτό το range να έχουν ξεχάσει να τις κλίσουν.
tin 21 den tin exoun kai pote den tin eixan kai efoson to ip einai stathero logo provlimatos tous den to vrisko paralogo na kovoun tis thires...an thes na stiseis webserver i mailserver tote to paketo pou sou kanei einai to eteriko kai oxi to aplo ;)
san na les oti agorases mia apli ekdosi aftokinitou kai einai alites pou den vazoun pano kai to turbo pou exei i kali ekdosi...oti plironeis pereis...
Βασικά η vivodi σαν ISP είνα μια πονεμένη ιστορία' date=' που έχει ταλαιπωρήσει και εμένα απίστευτα, μόνο και μόνο, επειδή έχω τα Services ΠΟΥ ΚΟΒΟΥΝ πάνω απο το ADSL εδώ και 1μισι χρόνο. Το "πακέτο" που μου κάνει εδώ και 7 μήνες, είναι της HOL (?14) και όχι τα "εταιρικά" της vivodi (?50+). [έχω DSLAccess από vivodi μόνο, και ISP HOL'].
Επίσης, κάνεις μερικά σοβαρά λάθη και λες πράματα που δεν ισχύουν, παρά μόνο στα χαλασμένα μυαλά της vivodi:
1. Το να έχω incoming traffic σε μια internet σύνδεση δεν είναι extra, αλλά standard. Μόνο οι κομμώτριες της vivodi το σκέφτηκαν ως τον νέο τρόπο marketing. Είναι σαν να πουλάνε όλοι αυτοκίνητο με 4 ρόδες, η vivodi να σου έχει βγάλει επίτηδες μια ρόδα από το αυτοκίνητο που σου πουλά , και αν θες την 4η ρόδα για να κάνεις δουλειά σου να πληρώνεις τα 3πλάσια. Νταβατζιλίκι.
2. Το να κάνεις filtering πρέπει να το γράφεις έστω και στα ψιλά, στην σύμβαση. Αν δεν το λες, διαπράτεις το αδίκημα της "απάτης", αφού άλλα λες οτι πουλάς κι αλλα πουλάς.
3. Τα 21,25,80,110 τα κόβανε και μάλλον ακόμα τα κόβουν, αλλά για κάποιο λόγο όχι σε πακέτα που έχουν DSLphone . Μάλλον κατα τύχη ξεχάσανε να το κάνουν ή ίσως ακόμα και το filtering να είναι κατι που ξεχάσανε να βγάλουνε.
4. Το πρόβλημα με τις dynamic που είναι static να το λύσουν σωστά και όχι κόβοντας services, διότι απλά θα χάνουν πελάτες .
Επειδή ΕΣΥ δεν χρειάζεσαι τα services που κόβουν, γι αυτό είσαι σε θέση να λες "να πάτε στα εταιρικά πακέτα", εγώ θέλω να αρχίσουν να σας κόβουν όλα τα Incoming ώστε να γίνει σκούπα και σε όλα τα "active" P2P, και να σας λένε να πάρετε το DSLnet+ (x3 τιμή). Εκεί να σε δω αν θα έχεις ακόμα την ίδια άποψη.
Αυτά, προς αποκατάσταση της κοινής λογικής.
SOSTI i apopsi apla einai atelioto thema kai exei anixtei kai allo thema gia tin vivodi kai gia ola ta paraxena pou exei kanei.to thema legetai nomizo ti ginetai me tin vivodi telika.tespa.exei kanei poles blakies pou kapoious tous simfernoun kai kapious allous oxi.
